INRIA
VMKit2 Project
Laboratoire d'Informatique de Paris6
Publications - Abstracts
Overview
Get Started
Tutorial
Mailing Lists
Publications
[1] Nicolas Geoffray, Gaël Thomas, Julia Lawall, Gilles Muller, and Bertil Folliot. VMKit: a substrate for managed runtime environments. In Proceedings of the international conference on Virtual Execution Environments, VEE '10, pages 51-62, Pittsburgh, PA, USA, 2010. ACM. [ bib | .pdf ]
Managed Runtime Environments (MREs), such as the JVM and the CLI, form an attractive environment for program execution, by providing portability and safety, via the use of a bytecode language and automatic memory management, as well as good performance, via just-in-time (JIT) compilation. Nevertheless, developing a fully featured MRE, including e.g. a garbage collector and JIT compiler, is a herculean task. As a result, new languages cannot easily take advantage of the benefits of MREs, and it is difficult to experiment with extensions of existing MRE based languages.
This paper describes and evaluates VMKit, a first attempt to build a common substrate that eases the development of high-level MREs. We have successfully used VMKit to build two MREs: a Java Virtual Machine and a Common Language Runtime. We provide an extensive study of the lessons learned in developing this infrastructure, and assess the ease of implementing new MREs or MRE extensions and the resulting performance. In particular, it took one of the authors only one month to develop a Common Language Runtime using VMKit. VMKit furthermore has performance comparable to the well established open source MREs Cacao, Apache Harmony and Mono, and is 1.2 to 3 times slower than JikesRVM on most of the DaCapo benchmarks.
[2] Nicolas Geoffray, Gaël Thomas, Gilles Muller, Pierre Parrend, Stéphane Frénot, and Bertil Folliot. I-JVM: a Java virtual machine for component isolation in OSGi. In Proceedings of the international conference on Dependable Systems and Networks, DSN '09, pages 544-553, Estoril, Portugal, 2009. IEEE Computer Society. [ bib | .pdf ]
The OSGi framework is a Java-based, centralized, component oriented platform. It is being widely adopted as an execution environment for the development of extensible applications. However, current Java Virtual Machines are unable to isolate components from each other. For instance, a malicious component can freeze the complete platform by allocating too much memory or alter the behavior of other components by modifying shared variables. This paper presents I-JVM, a Java Virtual Machine that provides a lightweight approach to isolation while preserving compatibility with legacy OSGi applications. Our evaluation of I-JVM shows that it solves the 8 known OSGi vulnerabilities that are due to the Java Virtual Machine and that the overhead of I-JVM compared to the JVM on which it is based is below 20%.
[3] Nicolas Geoffray, Gaël Thomas, Charles Clément, and Bertil Folliot. A lazy developer approach: building a JVM with third party software. In Proceedings of the international symposium on Principles and Practice of Programming in Java, PPPJ '08, pages 73-82, Modena, Italy, 2008. ACM. [ bib | .pdf ]
The development of a complete Java Virtual Machine (JVM) implementation is a tedious process which involves knowledge in different areas: garbage collection, just in time compilation, interpretation, file parsing, data structures, etc. The result is that developing its own virtual machine requires a considerable amount of man/year. In this paper we show that one can implement a JVM with third party software and with performance comparable to industrial and top open-source JVMs. Our proof-of-concept implementation uses existing versions of a garbage collector, a just in time compiler, and the base library, and is robust enough to execute complex Java applications such as the OSGi Felix implementation and the Tomcat servlet container.
Last update: September 16 2012 16:06:50.
